									Which wall mount is most compatible with Sony TV models? - TV				            </title>
            <link>https://forum.sony-rumors.com/tv/which-wall-mount-is-most-compatible-with-sony-tv-models-99497/</link>
            <lastBuildDate>Wed, 10 Jun 2026 21:53:07 +0000</lastBuildDate>
                        <title>Re: Which wall mount is most compatible with Sony TV models?</title>
                        <link>https://forum.sony-rumors.com/tv/which-wall-mount-is-most-compatible-with-sony-tv-models-99497/#post-12980</link>
                        <pubDate>Sun, 15 Mar 2026 03:46:54 +0000</pubDate>
                        <description><![CDATA[Re: &quot;Like someone mentioned, that offset&#039;s really problematic. Unfortunately,...&quot; - honestly its a scam. In my experience, Sonys weird design creates safety risks... feels like the TVs gonna...]]></description>
                        <content:encoded><![CDATA[<p>Re: "Like someone mentioned, that offset's really problematic. Unfortunately,..." - honestly its a scam. In my experience, Sonys weird design creates safety risks... feels like the TVs gonna fall, drives me crazy tho.</p>]]></content:encoded>
						                            <category domain="https://forum.sony-rumors.com/tv/">TV</category>                        <dc:creator>CheekyNandos42</dc:creator>
                        <guid isPermaLink="true">https://forum.sony-rumors.com/tv/which-wall-mount-is-most-compatible-with-sony-tv-models-99497/#post-12980</guid>
                        <link>https://forum.sony-rumors.com/tv/which-wall-mount-is-most-compatible-with-sony-tv-models-99497/#post-12979</link>
                        <pubDate>Sun, 15 Mar 2026 03:16:45 +0000</pubDate>
                        <description><![CDATA[Like someone mentioned, that offset&#039;s really problematic. Unfortunately, most cheap brackets fail to account for this properly.Perlesmith PSSFK1 Tilting TV Wall Mount Check the Sanus HeightF...]]></description>
                        <content:encoded><![CDATA[<p>Like someone mentioned, that offset's really problematic. Unfortunately, most cheap brackets fail to account for this properly.<br><ul><br><li><a href="https://www.bhphotovideo.com/c/search?Ntt=Perlesmith+PSSFK1+Tilting+TV+Wall+Mount&#038;BI=8941&#038;KBID=10361&#038;SID=12345&#038;DFF=d50" target="_blank" rel="nofollow sponsored">Perlesmith PSSFK1 Tilting TV Wall Mount</a> Check the Sanus HeightFinder tool... it's vital for precision.</li><br></ul></p>]]></content:encoded>
						                            <category domain="https://forum.sony-rumors.com/tv/">TV</category>                        <dc:creator>StaInfity</dc:creator>
                        <guid isPermaLink="true">https://forum.sony-rumors.com/tv/which-wall-mount-is-most-compatible-with-sony-tv-models-99497/#post-12979</guid>
                        <link>https://forum.sony-rumors.com/tv/which-wall-mount-is-most-compatible-with-sony-tv-models-99497/#post-12976</link>
                        <pubDate>Sun, 15 Mar 2026 02:36:53 +0000</pubDate>
                        <description><![CDATA[Tbh you really have to be careful with the X90L because of those bottom-heavy VESA holes. If you aren&#039;t super precise with your drill, you&#039;ll end up with that TV way higher than you wanted. ...]]></description>
                        <content:encoded><![CDATA[<p>Tbh you really have to be careful with the X90L because of those bottom-heavy VESA holes. If you aren't super precise with your drill, you'll end up with that TV way higher than you wanted. I've seen it happen a dozen times. Make sure to double-check the vertical rail length on whatever mount you pick. You want rails that are long enough so you can hook the TV onto the wall plate using the very top section of the bracket's range. Keep these technical bits in mind:<br><ul><br><li>Measure the distance from the bottom holes to the bottom edge of the TV before drilling</li><br><li>Look for a mount with a wide wall plate for lateral shifting</li><br><li>Watch out for fixed mounts that don't allow any vertical sliding You might want to consider the <a href="https://www.bhphotovideo.com/c/search?Ntt=Echogear+Low+Profile+Fixed+TV+Wall+Mount+EGLF2&#038;BI=8941&#038;KBID=10361&#038;SID=12345&#038;DFF=d50" target="_blank" rel="nofollow sponsored">Echogear Low Profile Fixed TV Wall Mount EGLF2</a> since it's sturdy and handles that weight easily. Honestly, just skip the $250 Sony bracket, it's a total rip-off for what it is.</li><br></ul></p>]]></content:encoded>
						                            <category domain="https://forum.sony-rumors.com/tv/">TV</category>                        <dc:creator>michael_ramirez</dc:creator>
                        <guid isPermaLink="true">https://forum.sony-rumors.com/tv/which-wall-mount-is-most-compatible-with-sony-tv-models-99497/#post-12976</guid>
                        <link>https://forum.sony-rumors.com/tv/which-wall-mount-is-most-compatible-with-sony-tv-models-99497/#post-12972</link>
                        <pubDate>Sun, 15 Mar 2026 02:12:42 +0000</pubDate>
                        <description><![CDATA[Yeah, that low VESA placement on Sony sets like the X90L is a total pain. If you use a basic fixed mount, it usually ends up looking way too high. You definitely dont need to drop $250 on th...]]></description>
                        <content:encoded><![CDATA[<p>Yeah, that low VESA placement on Sony sets like the X90L is a total pain. If you use a basic fixed mount, it usually ends up looking way too high. You definitely dont need to drop $250 on the official Sony one though. I usually point people toward mounts with vertical adjustment because they give you that extra wiggle room to shift the screen down a few inches after its bolted in. Here are a few that actually play nice with the X90L:<br><ul><br><li><a href="https://www.bhphotovideo.com/c/search?Ntt=ECHOGEAR+Full+Motion+TV+Wall+Mount+EGLF2&#038;BI=8941&#038;KBID=10361&#038;SID=12345&#038;DFF=d50" target="_blank" rel="nofollow sponsored">ECHOGEAR Full Motion TV Wall Mount EGLF2</a></li><br><li>This is about $100 and has enough vertical shift to fix the alignment.</li><br><li><a href="https://www.bhphotovideo.com/c/search?Ntt=Sanus+VLT7-B2+Advanced+Tilt+4D+Mount&#038;BI=8941&#038;KBID=10361&#038;SID=12345&#038;DFF=d50" target="_blank" rel="nofollow sponsored">Sanus VLT7-B2 Advanced Tilt 4D Mount</a></li><br><li>Usually $130 and lets you pull the TV out for easy cable access. Basically, just look for something with vertical rails. It makes the install way less stressful since you dont have to be 100% perfect with the wall plate height. Good luck getting it done before your sister arrives... you got this.</li><br></ul></p>]]></content:encoded>
						                            <category domain="https://forum.sony-rumors.com/tv/">TV</category>                        <dc:creator>Annarida</dc:creator>
                        <guid isPermaLink="true">https://forum.sony-rumors.com/tv/which-wall-mount-is-most-compatible-with-sony-tv-models-99497/#post-12972</guid>
                        <title>Which wall mount is most compatible with Sony TV models?</title>
                        <link>https://forum.sony-rumors.com/tv/which-wall-mount-is-most-compatible-with-sony-tv-models-99497/#post-12970</link>
                        <pubDate>Sun, 15 Mar 2026 02:12:24 +0000</pubDate>
                        <description><![CDATA[Just got a 65 inch Sony X90L for my living room and I&#039;m trying to get it mounted before my sister visits next weekend. I did some digging and saw the official Sony SU-WL850 mount, but man, $...]]></description>
                        <content:encoded><![CDATA[<p>Just got a 65 inch Sony X90L for my living room and I'm trying to get it mounted before my sister visits next weekend. I did some digging and saw the official Sony SU-WL850 mount, but man, $250 is way over my budget for just a bracket.</p>
<p>I looked at Sanus options too, but I read that Sony puts their VESA holes really low on the back, so universal mounts end up making the TV sit way too high on the wall. I'm really worried about the alignment looking wonky. Is there a specific mount that works better with that low hole placement or do I actually need the overpriced Sony one?</p>]]></content:encoded>
						                            <category domain="https://forum.sony-rumors.com/tv/">TV</category>                        <dc:creator>Alices</dc:creator>
                        <guid isPermaLink="true">https://forum.sony-rumors.com/tv/which-wall-mount-is-most-compatible-with-sony-tv-models-99497/#post-12970</guid>
