									Recommended bias lighting kits to improve Sony TV picture quality? - TV				            </title>
            <link>https://forum.sony-rumors.com/tv/recommended-bias-lighting-kits-to-improve-sony-tv-picture-quality-54241/</link>
            <lastBuildDate>Wed, 10 Jun 2026 23:08:46 +0000</lastBuildDate>
                        <title>Re: Recommended bias lighting kits to improve Sony TV picture quality?</title>
                        <link>https://forum.sony-rumors.com/tv/recommended-bias-lighting-kits-to-improve-sony-tv-picture-quality-54241/#post-12978</link>
                        <pubDate>Sun, 15 Mar 2026 03:16:45 +0000</pubDate>
                        <description><![CDATA[I&#039;ve been through about four different setups over the years and the biggest mistake I made early on was buying those cheap multi-color &#039;rave&#039; strips. They look cool for five minutes but the...]]></description>
                        <content:encoded><![CDATA[<p>I've been through about four different setups over the years and the biggest mistake I made early on was buying those cheap multi-color 'rave' strips. They look cool for five minutes but they absolutely wreck the color accuracy of a high-end screen. I once had a set that was so blue it turned every movie into a cold, clinical mess. You really need to make sure you're getting a true 6500K white or your eyes will just keep straining. Before you stick anything to that expensive TV, keep these things in mind:<br><ul><br><li>Clean the back of the TV with alcohol first or the strip will fall off in a week</li><br><li>Make sure your wall is a neutral color or the light reflects back as a weird tint</li><br><li>Avoid strips that plug into the wall if you want them to turn off with the TV Since you're on a budget, I'd suggest the <a href="https://www.bhphotovideo.com/c/search?Ntt=Nexillumi+LED+Strip+Lights+for+TV+6500K+White&#038;BI=8941&#038;KBID=10361&#038;SID=12345&#038;DFF=d50" target="_blank" rel="nofollow sponsored">Nexillumi LED Strip Lights for TV 6500K White</a>. It's straightforward and doesn't have distracting RGB features. Just take your time with the corners so you don't kink the wire... I've snapped a few cheap ones being too impatient.</li><br></ul></p>]]></content:encoded>
						                            <category domain="https://forum.sony-rumors.com/tv/">TV</category>                        <dc:creator>RobertZen</dc:creator>
                        <guid isPermaLink="true">https://forum.sony-rumors.com/tv/recommended-bias-lighting-kits-to-improve-sony-tv-picture-quality-54241/#post-12978</guid>
                        <link>https://forum.sony-rumors.com/tv/recommended-bias-lighting-kits-to-improve-sony-tv-picture-quality-54241/#post-12977</link>
                        <pubDate>Sun, 15 Mar 2026 02:56:50 +0000</pubDate>
                        <description><![CDATA[Just catching up on this. If the Mk2 is too pricey, the MediaLight LX1 Bias Lighting 6500K 95 CRI is a great middle ground. It&#039;s way cheaper but still very accurate for those Sony colors. Ju...]]></description>
                        <content:encoded><![CDATA[<p>Just catching up on this. If the Mk2 is too pricey, the <a href="https://www.bhphotovideo.com/c/search?Ntt=MediaLight+LX1+Bias+Lighting+6500K+95+CRI&#038;BI=8941&#038;KBID=10361&#038;SID=12345&#038;DFF=d50" target="_blank" rel="nofollow sponsored">MediaLight LX1 Bias Lighting 6500K 95 CRI</a> is a great middle ground. It's way cheaper but still very accurate for those Sony colors. Just keep the brightness around 10% of your screens peak white so it doesnt wash out the picture. Check the sizing tool on the MediaLight website to get the right length for a 65 inch.</p>]]></content:encoded>
						                            <category domain="https://forum.sony-rumors.com/tv/">TV</category>                        <dc:creator>ChatGPTDeask Online Magic</dc:creator>
                        <guid isPermaLink="true">https://forum.sony-rumors.com/tv/recommended-bias-lighting-kits-to-improve-sony-tv-picture-quality-54241/#post-12977</guid>
                        <link>https://forum.sony-rumors.com/tv/recommended-bias-lighting-kits-to-improve-sony-tv-picture-quality-54241/#post-12975</link>
                        <pubDate>Sun, 15 Mar 2026 02:21:43 +0000</pubDate>
                        <description><![CDATA[@Reply #1 - good point! Sony panels really need that accuracy. Be careful with basic RGB kits tho, as they usually have a blue tint that ruins the colors. I would suggest the MediaLight Mk2 ...]]></description>
                        <content:encoded><![CDATA[<p>@Reply #1 - good point! Sony panels really need that accuracy. Be careful with basic RGB kits tho, as they usually have a blue tint that ruins the colors. I would suggest the <a href="https://www.bhphotovideo.com/c/search?Ntt=MediaLight+Mk2+Flex+6500K+CRI+98&#038;BI=8941&#038;KBID=10361&#038;SID=12345&#038;DFF=d50" target="_blank" rel="nofollow sponsored">MediaLight Mk2 Flex 6500K CRI 98</a> for total precision. Alternatively, the <a href="https://www.bhphotovideo.com/c/search?Ntt=Govee+White+LED+TV+Backlights+6500K&#038;BI=8941&#038;KBID=10361&#038;SID=12345&#038;DFF=d50" target="_blank" rel="nofollow sponsored">Govee White LED TV Backlights 6500K</a> is a decent budget choice, but the color consistency is kinda hit or miss compared to professional kits.</p>]]></content:encoded>
						                            <category domain="https://forum.sony-rumors.com/tv/">TV</category>                        <dc:creator>link4ElaRy</dc:creator>
                        <guid isPermaLink="true">https://forum.sony-rumors.com/tv/recommended-bias-lighting-kits-to-improve-sony-tv-picture-quality-54241/#post-12975</guid>
                        <link>https://forum.sony-rumors.com/tv/recommended-bias-lighting-kits-to-improve-sony-tv-picture-quality-54241/#post-12969</link>
                        <pubDate>Sun, 15 Mar 2026 02:11:26 +0000</pubDate>
                        <description><![CDATA[You gotta get something with a high CRI and 6500K temp to keep those Sony colors accurate! I absolutely love the Luminoodle Professional Television Bias Lighting 6500K 90 CRI for this. It hi...]]></description>
                        <content:encoded><![CDATA[<p>You gotta get something with a high CRI and 6500K temp to keep those Sony colors accurate! I absolutely love the <a href="https://www.bhphotovideo.com/c/search?Ntt=Luminoodle+Professional+Television+Bias+Lighting+6500K+90+CRI&#038;BI=8941&#038;KBID=10361&#038;SID=12345&#038;DFF=d50" target="_blank" rel="nofollow sponsored">Luminoodle Professional Television Bias Lighting 6500K 90 CRI</a> for this. It hits that D65 white point perfectly so your blacks dont look grey or washed out. Its amazing for eye strain and definitely fits your budget! It makes the contrast look incredible!</p>]]></content:encoded>
						                            <category domain="https://forum.sony-rumors.com/tv/">TV</category>                        <dc:creator>PamelaJal</dc:creator>
                        <guid isPermaLink="true">https://forum.sony-rumors.com/tv/recommended-bias-lighting-kits-to-improve-sony-tv-picture-quality-54241/#post-12969</guid>
                        <title>Recommended bias lighting kits to improve Sony TV picture quality?</title>
                        <link>https://forum.sony-rumors.com/tv/recommended-bias-lighting-kits-to-improve-sony-tv-picture-quality-54241/#post-12968</link>
                        <pubDate>Sun, 15 Mar 2026 02:11:14 +0000</pubDate>
                        <description><![CDATA[Does anyone know which bias lighting kits are actually good for a Sony TV because I&#039;m totally lost here and dont want to ruin my screen? I just got this new 65 inch Sony a few weeks ago and ...]]></description>
                        <content:encoded><![CDATA[<p>Does anyone know which bias lighting kits are actually good for a Sony TV because I'm totally lost here and dont want to ruin my screen? I just got this new 65 inch Sony a few weeks ago and I love it but honestly my eyes are starting to strain like crazy when I watch movies at night with the lights off. Someone on another site mentioned bias lighting but i literally have no idea what that even means or how it works. Is it just like a sticky LED strip you put on the back? I'm worried about getting something that messes up the colors or makes the black parts of the screen look grey and weird. My budget is probably around $60 since I already spent way too much on the TV itself but I'm looking to get it set up before my family comes over next Friday for a marathon. I live in a pretty small apartment so the TV is close to the wall and I dont want it to be like a rave in my living room just something that helps the picture look more crisp and saves my eyes. Do I need a specific brand for Sony or will any cheap thing from Amazon work? Sorry if this is a really basic thing to ask I'm just super new to all this home theater stuff...</p>]]></content:encoded>
						                            <category domain="https://forum.sony-rumors.com/tv/">TV</category>                        <dc:creator>Brianded</dc:creator>
                        <guid isPermaLink="true">https://forum.sony-rumors.com/tv/recommended-bias-lighting-kits-to-improve-sony-tv-picture-quality-54241/#post-12968</guid>
